Well some good news about pictures......I will be getting a new Galaxy 7 edge phone in about a week so my
pictures will soon be Awesome!
. But until then I got more
to show ya'll......
Having too much fun with this radio and electric schtuff! A little bit about this 1400 mm EPO Foamy Sbach. Even at five pounds it is a solid flyer! But out of the box mine was less than ideal like the picture shows on HK. About 8 hours of additional work correcting the tail wheel, landing gear, different prop, cutting / drilling and balancing the supplied spinner, removing motor and mount for corrections, making better provision for cooling air and touch up of the applied scheme it has turned out NICE!
I consistently get 8 minute hovers holding the plane and blasting the throttle to mimic pull outs. After swapping out the prop with a modified TF 15x7 and pain stakenly modifying and balancing the spinner this thing is going to be a 3d beast! I almost can't believe it!
. I can get the motor to Idle at 1500 rpm instead of 2200 previously before the ESC cuts off. Very smooth throttle ups and very little if any vibrations! Prop tips track true through the rpm range making this power system as powerful and efficient as I could! The pack gets hand warm and the motor gets mildly hot to the touch. Can't wait to get some vid of it in the air!
