thurmma
Surveyed the damage to the 330LX when I had to dead stick it in again :( Not to bad. Actually have the gear block epoxied and curing. Should be able to get it back together tomorrow night and get what little bit of sheeting I need back in place so everything is ready for a nice shiny new power plant up front :) Hint, it is a rear carb :)
Saw this in the airport and thought it was a fitting theme...for many feats in the workshop, as well as business.
Robotech
If we listed possible manufacturers alphabetically, I bet it would be at the bottom. :attaboy:
Do-rag
Added mount for the second boat others will be added once I get it to nall because I do not want to unpack them.
Also bringing a GPS to check speeds this year so when I am asked I can tell them what they are running.
Xpress
You're letting us use these to retrieve augured airplanes out of the pond right? :oblong:
:D:laughing:
