Ohio AV8TOR
Just Do It
I would be more worried about the bacteria and pollution for the people. From one who has kept large high end Coral Marine aquariums foam fractionation is one of the best filtration systems that you can use. The foam is the result of a lot of disolved organics in the water and not the good kind either. That was a crazy amount and most likely caused by drains discharging to the coast near by.
RCAddict16
You think you have windy?.. check the attached photo, this was taken today in aberdeen at the seafront. The white stuff covering the ground, cars and houses is foam from the waves crashing ashore. These houses are 60m away from the actual water line.
So for those who think they can fly in high winds.. i challenge you! You might find fishing a bit tricky too:rolleyes:
Challenge accepted. : ill need a hotliner, a 1000 watts of power, and 3 gyros. ;)
That looks like bad news on the foam front...is that near nig bay??/ looks like it's breached and dumping raw effluent into the sea :(
On the fishing front - caught a 6ib carp - nice specimen but hardly worth writing about
quadracer
The 3DRCForums -OFF TOPIC- Thread
I got a few nice ones last summer; this met his fate with my arrow, and was the biggest, 47 lb.
RCAddict16
Wow! My biggest 2 were a 42 inch 24 pound flounder (massive), and a 9 pound bass. Things are going well on the foamie front....... my stuff is coming tommorow, and my drawing turned out to be kind of a pattern plane wing with big ailerons, and the crack yak tail. Should work well. Does it matter how far forward or back the wing is on the fuse?
Re: The 3DRCForums -OFF TOPIC- Thread
Woah! :(
SteveT.
Yumpin Yimminy!!! I must admit, that just "might" be a bit "challenging"!!! More like hang on to something, or "you" will go flying!!
SteveT
