I just flew mine for the first time today...That CG with the battery against the wing tube seems too far back after flying mine several times today and adjusting..I have the same setup as you for the most part...I`m about 1.75 forward of the wing tube ...Your gonna want that 45 degree on the elevator on high rate...I couldn`t get it to flat spin etc. without it...I had to swap to a longer control horn..As far as expo your gonna need a good bit so crank it up..I`m like 60-70% on high rates..Same for low...like 50%...I did not like my first few flights at all, but once I adjusted in it, all was good..It flys different than my 51 slick for sure..I`d set your timer for 5 min. and work from there. It easy to land so if you can just get it up and land it and start adjusting on it for your liking you`ll be good...Good luck...J
