Build log - RedwingRC EXTRA 330sc profile
Decal Dennis
TEAM EP&G
WORK WORK WORK has hindered progress some, but I got some goodies from Redwing:D and managed to get a little more done on the profile. I'm replacing the supplied DLE spark plug with Honda CM6's that I purchase at work.
Decal Dennis
TEAM EP&G
Also picked up some props, Danhakl tank and servo arms this past Saturday when I was at Tim's house installing some big Redwing RC decals on his trailer
Decal Dennis
TEAM EP&G
Kinda bombed on the build thread!!!....but the following posts are some pics of the finished plane, minus a couple of finishing details
Here...the phenolic rudder control horn just snapped off during preliminary testing of the rudder(scratching head....hmmmm). Pic of the fast fix.
Decal Dennis
TEAM EP&G
Here we got the installed Badger switch in the left wing, 3500mah battery(ignition and rx) is also in this wing.
Aileron and power quick connects from fuse to wings
Decal Dennis
TEAM EP&G
Hitec HS-5685MH high voltage servos all the way around with Redwing RC carbon arms and aluminum circle horns
Decal Dennis
TEAM EP&G
Engine, ignition and 4titude 8oz fuel tank mounted.
If you notice in the pics...It killed me to add some nose weight(dead weight) to achieve the approximate CG balance. I'm really hoping after a flight or 2 I feel the need to remove it!!
