DLE-85 Single Cylinder Petrol Engine
Lojik
SPECIFICATIONS
8.5HP/7500rpm
Idle Speed:1500 rpm/min
21Kg Static Thrust / 100 meters Altitude
18Kg Static Thrust / 1800 meters Altitude
Recommended propeller: 25×10?26×9?27×8?
Spark Plug?NGK CM6
85cm3
Diameter × Stroke : 52mm×40mm
Compression Ratio : 9.5?1
Fuel / Oil Ratio : 30:1
Weight: Main engine -1930g Exhaust pipe - 250g
Ignition equipment - 130g
Ignition voltage 4.8V-8.4V
Anyone have or running one of these, would be interested to know more about it.
3dNater
3DRCF Regional Ambassador
I don't have one, nor have I seen one... but boy, my initial thought is, that thing must shake like crazy... that is getting to be pretty big for a single cylinder engine. Even the 60cc engines shake pretty hard. I think I'd want a twin in that size.
3dmike
I've heard really great talk about the 85 and contrary to what you might think I've heard the DLE85 is super smooth and a stump puller. Can't say I remember seeing one in person... It's just what I've read and heard from friends.
