New Spektrum Powersafe Receivers
ghoffman
Integral mounts, telemetry, and less expensive than before.
Do you see the 2 antenna from the receiver one long one short. Wonder why they did that does anybody know the reason for this .
So that the longer one can be at right angles to the short one.
Are you guessing I have several spectrum receivers for gliders that just have two wires just like that are the same length that need to be at ninety degrees. All so futaba are the same and the wires are the same length. Don't get me wrong you could be right but why make the change now.??
Alky6
I assume the long one is for the telemetry - similar to the TM 1000. The short one could be for a receiver like the carbon fuse version receivers? Again another guess....
