Hangar 9 Ultra Stick 30cc ARF
rmyers
Well, this does weigh 2 pounds more than the US 120 Lite that I had the DLE-30 on. And with rear mounted servos, it should balance. I was thinking of the VVRC 40 twin, but the DA-50 is basically the same weight.
VVRC 40 on a Giant Stik flies great.
I like the idea of the vvrc 40cc twin, hard to beat a da-35 as well... of course these are the higher priced engines. The twin would be easier on vibration with the supplied CA hinges.... just sayin. The vvrc 40 would be my choice.
ghoffman
If I get one of these, I will not use CA hinges. I ended up having to replace them all with Robarts on the previous Stick, because they all ripped with only a DLE-30 for power.
rmyers
I used Robart hinges on the Giant Stik. I just don't like CA hinges.
ghoffman
I read somewhere, the firewall is 110mm square. So I drew up the templates for DLE-35RA and DA-50 on the 110mm square. the first one is the DA-50.
I'm thinking Tacon 160 ($60) and 8s power, 100/120 amp Castle ESC. Should be plenty of power. I fly a 1/4 scale Bravo on that setup and plenty of power
