Peak Models 32% Extra 330 SC
So I guess this means you can get back to making that green/yellow banana flight ready. Maybe you can beat me with the Baby Yak-ster. Ah! Too late. It is done....:fist_pump:
Looks real nice Kelly. Looking forward to seeing it finished.
Great you got a clean diaper on that baby! Now go feed it so it gets good and strong :attaboy:.
As for the Extra......I will know if it's a boy or girl plane in a few weeks o_O.
The spinner looks really good for this plane. It is about 1' longer than the one I had on the V1.
Trying to decide if I want to paint it or not :confused:. The finish is very well done with a great glossy CF look :).
Whew......Now that other planes are out of my way I got some things done on the extra. Rudder pull pull tray, Prop and spinner back plate drilled, Fuel tank vent line and the engine mounting template installed awaiting a nice sharp 1/4" drill bit.
I extended the use of the drilling guide to also support the spinner for cowl alignment. It fits perfectly inside the CF tube. The drill guide itself is one of those single bolt prop shaft adaptors. IMO they were a bad idea for 50cc class engines but it turned out they work great for drill guides. Specially if you want to drill the prop and back plate together :attaboy:.
The new cowl is a much better fit but you can see how far off it is still compared to the lazer etched cross hairs.
1119171128-00.jpg 1119171124-00.jpg 1119171124-01.jpg 1119171128-01.jpg 1119171154-01.jpg 1119171154-00.jpg 1119171158-00.jpg 1119171158-02.jpg 1119171159-00.jpg 1119171200-00.jpg 1119171200-01.jpg 1119171203-01.jpg 1119171203-00.jpg 1119171204-00.jpg
Just about got the engine mounted. Need to make a trip to the Ace and get some SS 1/4-20x3.5" hex head bolts. The 3 inchers I got are not long enough to get a lock nut "backer" on the blind nut. Want to keep the inside of the plane and engine clean so looks like plenty of room for the air filter.
1119171447-00.jpg 1119171448-00.jpg 1119171500-00.jpg 1119171456-00.jpg 1119171456-01.jpg 1119171457-00.jpg
