They are definately power houses. I and my son had a number of those lil nitro guzzlers. I had a 135, 2-180's, a 210 and my 3.6 twin. My son had a 135 and 210. Truthfully, I owe my gas addiction to the high cost to run Moki's.I loved my Moki 2.10. One of the best glow engines ever.
All my glow engines are gone, deceased or sold. In that order. Why I keep a gallon of 30%, glow driver, electric starter and tachometer
is beyond me.
My flying buddy had an ACE Extra 230 that size with a Sach 3.2. Awesome flying airplane for the time. Sheeted foam wings, turtle deck, and a forest of wood in the fuselage, and we painted it, so it was plenty heavy. It would do the coolest Lomcovák that I've never been able to duplicate with any airplane since, and I could get it to do it every time. And we thought we had died and went to heaven with the Sach's 3.2 over the previous Quadra's.My first 50cc was a scratch built Godfrey Extra 300. Had a Brison 3.2 in it and a 82" WS. It weighed 18.5 pounds wet. And it was a sheeted foam wing with the fuse being built up and a foam turtle deck.
I still have a pumped O.S. .61 and two paper weights, I mean O.S. 120 Surpass engines.All my glow engines are gone, deceased or sold. In that order. Why I keep a gallon of 30%, glow driver, electric starter and tachometer
is beyond me.
I still have a kit and all the parts to duplicate it. Even the Sach's.
The problem with the mechanical advance on the one in the Extra 230 was you needed to take it apart now and then and lube where it rode on the crank snout or it would stick.They do look good when painted don’t care what anyone says. By the way theSach 3.2 you mentioned I had one it did have a blue crankcase. The one I had had the mechanical advance on side hooked up to the throttle linkage. Good engine had some good times with it until it drilled into big irrigation pipe at the end of the runway.
Man how in the hell do you remember those things, yes I do remember now that you mentioned it. And I am never going to admit how long I chased that one around before I figured it out..The problem with the mechanical advance on the one in the Extra 230 was you needed to take it apart now and then and lube where it rode on the crank snout or it would stick.
