SOLD! Revolectrix Cellpro 10XP 600 watt 15 amp charger
Status
Not open for further replies.
Charger is in like new condition, has been very lightly used.
It can charge up to 10S at 15 amps.
Will include printed manual. Have too many chargers, this one has to go.
$120.00 US Shipped.
Regards,
Dennis
Does it plug into a wall outlet or does it need a power supply?
Yes, It will require a power supply, and the bigger the better. My power supply is 24 volts and it ran it just fine. Charger will take anything from 10-32 volts input.
Regards,
Dennis
-The charger comes equipped with Cellpro brand (JST PA series times two, 6 position) balance connectors which enable the charger to monitor and independently charge each cell to its optimum level (balance charge operation).
-There is a 2 channel 6S adapter,
- There are also 2 4s adapter boards for balance charging up to 4S. These 2 adapters carry connections to all the major brand balance leads.
- There is a 6 wire to 5 wire adapter to allow use of the 2S balance boards.
- I also had it hooked up to a 4 port MPA board for parrallel charging 4 packs, but I will be keeping that as I can use it with my other chargers.
-I will however include the 2 channel MPA-to-Cellpro 10XP Charger Interconnect Cable as its only used with the 10XP.
-And finally, I will include the Charge Control Software (CCS) adapter. You download a free Microsoft Windows application from the Revolectrix website. This is compatible with Win7 and above. The CCS unleashes the full potential of Cellpro 10XP charger. The GUI is simple to use and allows access to basic charge parameters and chemistries for 10 user presets that can be stored in the charger. Graph charge and internal resistance data, adjust all charger options, update firmware easily and reliably, and much, much more...
Regards,
Dennis
Larz
Regards,
Dennis
Regards,
Dennis
Regards,
Dennis
Is it still for sale?
Status
