IMAC Scratch build Laser 200
Here is one wing, which is approximately 46 inches, not at the shop to measure, and the root chord is 24 inches, total wingspan is 98 inches, when back in the shop, I will make a proper measurement and if needed will repost here
rudder assembled more work to be done, you can see my faithful inexpensive table saw I use, and you can see what I did for precision, the first thing a large piece of plexiglass to have a smooth surface , then I'm using an old aluminum level as a fence , it works
