Scale 20cc DHC-2 "Beaver" Kit Build from Moustache Model Works
Got some tinker time today. Hinged the ailerons and flaps with my robart hinges, added some spacers to get my control surface gaps right. My plans are off a bit due to shrinkage. But it looks good now. I will be adding LED lights, so decided to start cutting the wing tips to accommodate them.
Next I’ll install my landing lights, wiring, and possibly blind nuts for my wing struts.
53261C38-09E2-4783-B8B2-737BFCC3E5E9.jpeg EA33FCED-61E6-43E5-8B9D-C89269EA758E.jpeg 9CB09EFF-980B-48BF-BF7F-5962AFF5EE99.jpeg CF9B4DE0-9478-4E28-84DA-6FEAA43C5A3D.jpeg 42ED29B1-30BB-4FA2-A2D8-05565C8E4601.jpeg 1CCF1CF0-11CB-4DF1-9B00-D0ED77D91BDF.jpeg 7DD94A27-F3C7-4C84-99E3-352FDF2904D5.jpeg DC1558A1-8A33-4AA6-A898-FCBC82A27DAD.jpeg FB24FBA6-4D49-4B8C-99E1-F1FCB2563645.jpeg 02CD3D7A-AC88-48A3-8C79-D4335BF7A692.jpeg 26D6A084-F951-41EB-8B26-E4D605BC76E4.jpeg E23575AF-4CE6-480D-99FE-C27DE85F985A.jpeg B7CB817E-842A-46EF-B3D6-FAE1E8788BFD.jpeg C16718AA-014B-4EED-B4F8-73FDDEA06002.jpeg A15F6234-7270-4EF9-A08E-2408EF239230.jpeg E78CE988-1443-4E62-8CD5-66BE68771234.jpeg B7DB47BF-E626-47E9-8AC7-4B3DA65DD544.jpeg
Looking good brother.
Thanks Mike! Trying to keep this project rolling! I’m eager to cover it! So many little details!
speaking of details, I’ve been thinking... I want to design and make a PCB board for my light system that I designed years ago. Probably outdated, but it’ll be a fun project none the less. Would be neat to get it working and make a little DIY kit. My etched board is going in the otter, my rats nest is going in this plane... unless I can make a real PCB. How cool would that be.
I coming along nicely, nice clean work. The kit looks good but not the easiest to build. Led will look goood on that plane.
Ok do either of you go to bed, looking at the times the two of you were on the site 3am
my time stamp says 11pm, I think you’re time zone is different? AKST here
sleep is essential with a toddler LOL
Using some old ribbon cable that was given to me, I started routing the light system.
ypu can tell this was an afterthought based on how everything is routed. Instead of going through the formers and ribs, I went around them. Not a big deal. Used superglue and kicker to adhere them.
for the tail light I used a piece of tubing that sits flush with the balsa tailpiece. There are many beaver tail cone styles out there and this way it actually looks scale to the one I’m modeling after which was a bonus.
8195E679-AE17-4E55-8EFF-04A11EE0E641.jpeg 337BA8B8-764B-404A-B040-765CD4290ADA.jpeg 1B760B6F-BC77-463F-A066-D320E9A0231F.jpeg 670976CB-A80E-427F-B63A-659225E893D6.jpeg 0D5522D7-05F7-4933-BFF1-895618E81F4C.jpeg 6C902A64-2DF1-4239-B0C1-9AE936F74BE3.jpeg 3DDD941C-F900-4DFE-8EB9-D2F1AB3255F4.jpeg B407177E-F1D7-47E5-A671-2D4B1171E477.jpeg
Nice job on the elevator cross link, they are difficult to do nicely and neat looks good. Hard to get enough through from that setup.
Seen a guy on a FB group that had made a little access hole for the rudder linkage. I figured why not! So I made one just in case I need access to the connection.
Pretty much just made a little oval hole with some doublers just below the stab doubler, and used a couple little countersunk screws to attach them. I’m going to cover over it, so it’s there if I ever need it...probably will never use it.
B391E0C1-A34B-4D99-86CC-71DE695F6D1F.jpeg 6397F159-1615-4B97-AB26-457F343A3AA8.jpeg 0F9B235C-8B17-42FB-81D5-62F85F35A1CE.jpeg 0BCE2DE4-D95F-487D-9E4E-5BCCEAD77A02.jpeg 4D317C7D-EC39-47B7-8D38-FC13D31F9EA2.jpeg 3D2AA5F7-AEF8-403C-BB8B-5F4CB8C406ED.jpeg F57DCA93-BED0-450A-A5AF-E873DBBA10A5.jpeg 9150A76A-2101-4F5B-B4EA-9AB6627E275F.jpeg BEE4823C-BE21-48F2-849D-9316689C0759.jpeg
