HELP ix12 mixing
The Treetop Flyer
I have a ix12 and 12 ch power safe rx. I can't for the life of me figure out how to do a mix.
What I'm trying to do is have it where my flaps and ailerons work as one. To have a full wing length aileron at the flick of a switch, so to speak.
Also to have crow flap as well.
I have attached a picture of the monitor screen. And I can email you the ispm file to edit.
Thanks in advance,
Gary
Thanks in advance,
Gary
I believe the programming logic should be similar to the DX9 so I can tell you how I did crow, but will need to study the approach to flaperon mixing.
Would you please let me know the number of servos you’re using on the wing. I assume 4 servos - 1 for each aileron and 1 for each flap.
I found an approach which seems to work, but will need a bit more refinement to make it work the way you would like.
The DX9 may be programmed to use up to 5 Flight Modes - not sure about the iX12.
Normally I use Flight Modes as a way to control dual rates and expo.
However, Flight Modes may also be used to trigger the Flap System.
Similarly, Flight Modes may be used to trigger a mix.
In summary I used the Aircraft Type as 2 Aileron, 2 Flaps, and Dual Elevator Tail, together with one mix and the Flap System.
The mix is Aileron to Flap; Rate: 100%, 100%; Offset: 0%; Trim: Inh; Switch: Flight Mode 1, 2, 3
My test used all 5 flight modes as follows:
  • Flight Mode 1 - 25% aileron deflection, 15% expo, full span ailerons
  • Flight Mode 2 - 50% aileron deflection, 30% expo, full span ailerons
  • Flight Mode 3 - 100% aileron deflection, 60% expo, full span ailerons
  • Flight Mode 4 - High rates for ailerons, Flaps down 1/3
  • Flight Mode 5 - High rates for ailerons, Flaps down Full
Finally, one of the flight modes could be used for Crow, where two additional mixes would be required - one for throttle to aileron and the second for throttle to flap.
Hopefully this helps. I’m happy to answer any questions you may have.
The Treetop Flyer
Yes sit I'm using 4 servos in the wing
