Did a little sanding and fitting of all joins everything is done and the joints are nice and tight.
The weather still sucks cold , raining and extremely windy so guess what back in the shop building. Finished up the front plate for the motor and build the stabilizer and shaped it. Now I can fit the stabilizer into the fuselage and check how the wing and stabilizer line up.
Also prepared the wing for wing bolts so that it can be fitted to the fuselage. I learned this from a fellow flyer, he has been racing planes for many years and explained this procedure to me he explained that he has been doing this for a while and has not failed him. This is a foam wing covered with 1/16 balsa and 2 layers of 2oz cloth on the inside of the 1/16 balsa top and bottom. You drill 3/4 diameter hole for 1/4 bolt. Then you mix up epoxy with chopped glass and thickener until it is like ketchup. Then fill the holes properly and let harden, then sand smooth with the wing and then drill the epoxy for wing bolts. They do it like this for strength and nothing sticks above the wing and everything is flush with the top of the wing.
We’ll I am back in the workshop, it is really cold and raining again it is just above freezing.
Anyway build the stabilizer and separated the elevators. Prepared the fuselage and got the stabilizer square and straight with the wing. Now it is just a matter of time for the epoxy to cure. Then on to the rudder getting it built and installed.
