Bartman
Defender of the Noob!
Hey folks!
Got a few extra spinners? Need a spinner? Use this thread to put them up for sale.
The spinner below is no longer available.
I've got a 4" aluminum spinner, it has a part# stamped inside the cone and I was able to locate it online (mine is an AW72 with the solid backplate which is different from the lightened backplate in the link below)
http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=593
So it's an Airwild Nova, Extra style 4" 2-blade, here are a couple of pics, i used a steel insert to make it fit the engine that I had it on but the actual hole is drilled to 1/2". I can pop the insert out and use drill bits to get a more accurate bore dimension for you if you'd like.
I'm looking for a 3", 2 blade spinner. aluminum, red, or white, normal style.
Also looking for a 3.5" Extra style like the one above for a 2 blade prop, DA50
