3D 30cc hazzbro extra
Wow I think your right. Is this a common way
When I built my lamyak 40 I just glued the bottom spar at the root ribs and then did everything needed to the top of the wing. After I was done with the top I flipped it over and then pressed the spar all the way into the slot and finished gluing it.
Looking good. Keep asking questions when you have them. We want you to have the best slab experience possible. They are more fun than you could ever imagine.
Couldn't I just place bottom spar down. Then put ribs in and square them but not glue. Then put in top spar and glue
Yup that should work. Like Kenny said another good tip is to use some sort of strait edge across the trailing edge of the ribs to help keep everything lined up well. If I was at home I would take a picture of what he is saying do but I'm working tonight.
kwj48
You could but I would put in the tube sleeve before starting to glue also. It kinda helps keep things lined up also.
daman691003
I started the wing. Everything looks nice and straight. I decided to make some doublers for the wing tube. Think they are needed.
daman691003
So my wing tube isn't long enough. And it looks like I'm missing the donut doublers. But I made my own. For the price of this kit it is very disappointing.
