ChickenBalls
"Cool Guy"
Well looks like it wasn't radio after all. Rob it was the A9Dang that sucks. May I ask what radio system?
Man that sucks. I'm really glad no one was hurt. Did you have a fail safe set on the throttle?
About 2 years ago I had a throttle servo go nuts on start up and try to eat me. Thankfully I had it tied down well.![]()
He has opti on it, if radio looses signal, engine will die, hence why we couldn't figure out lock out. He had throttle buried down. I think we found the problem.
I had that happen to me also. I was using the A9 and for some reason every now and again the throttle wouldn't come up when powered up, everything worked, ailerons, ele.,rudder, but no throttle, flipped prop that bitch came to life wide open. I was moving kinda fast for an old dude getting away from that thing. I always check throttle before flipping, make sure I hear it working now
Gents look at the taxi back pic. I noticed it also, but the owner just called me and he saw what I saw. The motor is broke loose from standoffs, there was 3 of the bolts broken. Looks like he broke one sometime back, and then the others failed, you can see in the pic the engine is turned, and the prop is spooling up. Congrats Warren on finding what happened, glad it wasn't radio related, hard to put trust in radio after a glitch.
