Thanks Mike and David!
Just some info on the set up.........The recommended cg for first flights is 27% MAC per the manual. This comes out to be 6.9 inches back from LE at root. On the model it put this cg location 1/4 inch behind the wing tube. Once I got my expo issue resolved I noticed I had not touched the trims at all on the next two flights I had with it! This is the first Peak Models I have ever had this happen with.
So bottom line call on this airframe for a bottom line price is
stars. I would recommend this plane to every one
Other than the shipping damage I had the only very minor issue is the landing gear height. It is about 8" from axel hole to bottom of its cross section. If you are going to swing a 24 or 25 inch diameter prop I strongly recommend a landing gear that has 10 to 12 inches from mentioned reference points.
I still have some "customizing work" to do on the cowl as mentioned in the first start vid and baffles. Will get some vid of some shenanigans with it in the not to far off future
. Thanks every one for the positive comments and contributions to the thread.
