Here are a few documents that will help you understand how it works.
  • LS_Tutorial_20190225.pdf
  • OpenTX Diagram - Inputs.pdf
  • OpenTX Diagram - Mixes.pdf
  • OpenTX Diagram - Output.pdf
More tool items showed up!
Dremmel vise, gewlers glasses, a speed controler for a X-Axis drive, and a de-burring set.
Ordered this 5"four jaw chuck on Friday from Temu, it arrived on Sunday in a Vevor box? Have a 6" four jaw but it is a little too large and the DRO scale is in the way, when I use it need to cantilever the tools toward the chuck. The arpon and scale will fit under this chuck. Not a bad deal, $50 however need to buy another metric 39-4 6" adapter that cost twice as much as the chuck! Don't remember exactly what the problem was with the last adapter but do recall having a conversation the the Little Machine Shop owner.
Forgot about this purchase. Seems like the tools always interfere with the live center, hopefully the extended and reduced diameter will help out. The one on the left was $15, had the one on the right since 2006. Got to stop looking at the computer and spend more time on the Cherokee!
