Mini lathe (and mill) discussion.
It took quite a few chips to marry the 5" 4 jaw chuck to the 6" adapter, but it is done. Much better fit for the lathe, the carriage can pass under the chuck, not so for the 6" 4 jaw. Need a project for it now.
More tooling from AliExpress, adjustable VEE block and cutoff and grooving tools, 2mm through 5mm. Took two orders to get the cutoff tools, some of the items on the first order were canceled.
Recently picked up a 6 jaw from Vevor. Had to do some work to it right off the bat to make it function properly. Works good now and I can hold larger material. In the process of making a rotary table fixture plate.
Yep, it's a 6". Here's the first stage done. Once I had the section of material I was going to use faced and trued, I took it over to a friends and used his large bandsaw to cut it off. Then re-chucked it and the 6 jaw re-centered very well.
