Scale 20cc DHC-2 "Beaver" Kit Build from Moustache Model Works
AKNick
Nick the tail cone is it plastic and is it going to be covered with ultra coat. If is need detailed procedure if that is ok with you.
The tail cone consists of two vacuum molded plastic halves. They will be cut to fit, painted, and glued in place.
Any heat would deform these pieces easily, so they must be painted.
AKNick
Covered the elevator and rudder counterbalances deep blue. Heat gun helps with getting around the tips. Also covered the balsa tail cone center piece.
Thanks
9694F164-D5D3-4BC9-AC13-A2CB70240F99.jpeg D947BBBB-E3A7-45DA-9616-2E166CEC0A51.jpeg 44C64762-3336-4538-9CE2-CE4C30BF9DA2.jpeg 293D5523-B3ED-4458-B97C-1252ADAE466F.jpeg 1AC74512-F93F-42BB-B200-D6484B9447C0.jpeg FEC25AE4-D219-44B8-855E-C4A72E490A32.jpeg 59E1BD56-2094-4FA4-BD9B-1B793066AAE1.jpeg D8EE7A58-3AA7-4DAC-BD6F-26D51852057C.jpeg 65EF5063-CD19-4458-B618-86597A94FE98.jpeg A2EA1BEF-51B9-49B3-B153-7A1C8B040216.jpeg 26AA3698-598A-4B62-84BB-8FFB44FF5195.jpeg
AKNick
Hinged my rudder and elevators to their stabilizers.
As mentioned before I’m using robart pinned hinges instead of CA hinges. Mainly because I like of much more resilient they are with a gas engine.
Didn’t have too many pictures with the rudder because I am going to start to record video and post it on YouTube after some editing. I have quite a bit of fun editing and positing flight videos but recently I’ve been having an itch to start making and adding “How To” videos to my “AKNick” channel. So stay tuned.
For installing pinned hinges, my process goes like this:
Deplete a carbonated beverage of choice. Flip it upside down and smear some petroleum jelly (Vaseline) in your newly created reservoir. Bust out your heat gun of choice and liquify that jelly. Grab a pinned hinge and bend it to its extreme so you can emerge the pin in the liquid jelly. Bend it the other direction and dip it again. Set aside. The petroleum jelly will solidify as it reaches room temperature again. Presto, now you have a fully lubricated and sealed pin to prevent epoxy from going where you don’t want it ho during the next step.
Using 30min Zap Epoxy, I mix it up in a mixing cup with a small plastic dowel used for rod building finishing resin. Use the rod to coat the epoxy inside the hinge holes. Lightly cover one barbed end of the pin by smearing with the mixing rod and insert into one half of the control surface. Do this with all the pins. You should have little to no excess resin. Do the other side and repeat.
For the excess resin I use 99% isopropyl achohol on cut up paper towels and wipe clean.
Deflect the control surface many times while pushing together. Then tape both sides in place, use alignment boards/devices if you have to in order to keep everything flush. Allow sufficient time to cure, then be amazed of how smooth your control surface moves.
6D4F1276-F020-4463-8EC2-6D066766EDFF.jpeg 77FF7DDB-606D-4FDD-A664-C34F0E6C35FC.jpeg 5093D8A3-D9AE-4C7B-ABF1-1F57B3EA4A6F.jpeg AE9BA792-6914-42DE-BB5B-D6F2BFA405CD.jpeg 8CD8BD92-B78A-4EA7-815F-1146ABE2BCA2.jpeg EE07CC8B-BA9B-489A-A29B-FF555CD5DFD7.jpeg 44EE8405-495E-4A13-BD51-F6B7C53E01E3.jpeg F9032D61-5274-4D40-ACC9-F149AD046D64.jpeg 8A5CA3EF-8F11-435A-85EA-A4D0775F653A.jpeg DD1CD7B2-E486-4CD7-BFDA-9FCF0F8101D1.jpeg 12FD29AE-FD82-4B86-8409-87F2153F6CFB.jpeg E507C3FE-29B3-4BDC-BFD2-B617A21EA623.jpeg B03D8DC4-B53C-42A0-85AB-4CEF8D0B4A36.jpeg 64EB95BB-E7FF-461D-9E3B-2C0610AE8673.jpeg E0539AAF-3F45-47AD-89D3-6312761F2930.jpeg BD7D3526-B03E-4CA5-89F2-CF7F91F07198.jpeg A17C8532-01E5-4A9F-87CB-E4D66FF9E2FE.jpeg 12CA73AF-2845-46E0-8454-E92F3EF793DA.jpeg 6ED7B170-19CE-4982-A2C8-C7941E9A1C97.jpeg 38968E12-F9B7-4297-9EC6-7D1631D5357A.jpeg FD29F74D-3C10-4E3B-9193-549F7A432548.jpeg
WMcNabb
View attachment 117260 View attachment 117261 View attachment 117262 View attachment 117263 View attachment 117264 View attachment 117265 View attachment 117266 View attachment 117267 View attachment 117268 View attachment 117269 View attachment 117270 View attachment 117271 View attachment 117272 View attachment 117273 View attachment 117274 View attachment 117275 View attachment 117276 View attachment 117277 View attachment 117278 View attachment 117279 View attachment 117280
Excellent tutorial! Thanks for sharing this one.
AKNick
Epoxied the mid tail cone in place. Special care to keep it aligned with the elevators taped at neutral.
33C39FD1-649F-425D-AE7C-3CA81C37A549.jpeg 4EBC4C07-CCF1-442B-89DF-7FDEF331ACDD.jpeg BE0A4F20-6684-45A0-B539-E15546DCE385.jpeg B79A6E17-5F7C-4394-8D72-A4383E9B0DD4.jpeg 22C83E27-1809-473E-8F8C-8BC5BE45DDAF.jpeg
Prepping for the fuselage to be covered, I found nowhere in the manual where it talks about cutting the slot for the main landing gear legs. So after some digging I found the exact location and just made a few cuts in the balsa to accept the gear legs. Not rocket science, but wanted to make the cut prior to covering.
F664B5D6-CCCA-4032-8467-EAEE9608D689.jpeg A99EA3C9-BF78-43A0-B2A7-4C67C2FBE284.jpeg F1671575-D36A-4259-99DD-BB2017CC57B9.jpeg 08C12C34-98FF-43BD-84EB-7826AEFEF425.jpeg
AKNick
Busted out the bright yellow ultracote and started to cover my fuselage. Talk about visual progress. Decided to cover it sides first, then top. The bottom will be deep blue and a bit more technical on the cuts to match the livery. The only part that was challenging was the float fittings and the curves from the main cabin door going forward on the liver section. Made a couple incisions be the fittings to make it lay out right without wrinkles. Overall pretty pleased with the outcome. Note that if you roll out the ultracote you can make one cut and it will be used for both sides.
This process is easiest using a low iron temp to start and doing some heat gun touch ups.
6472E0BE-15AC-48B4-BDEF-0E45D48B5D36.jpeg C10FADDB-A670-40AD-9993-7FF31FF8121C.jpeg 1EE271AC-C35C-4C36-BDD1-694E80986510.jpeg A465D68A-1CE7-4171-BE11-C14C362CEAAB.jpeg 74052E8D-8384-465E-8CC7-0AED6636D665.jpeg 73E20EDE-2DFB-40EA-82A5-7581C289AAEC.jpeg 83E21567-C748-46EB-8678-6658DE6D8348.jpeg 7CC84B8D-A373-4EBE-A8D4-45FF9D0757CA.jpeg 9D20152B-BAA2-4F4B-A629-D8013C5406E5.jpeg 4031FEEE-373C-4856-A268-14BEB86573A7.jpeg F7F9463C-2C2A-4F24-8D9E-6863BCA9BEB5.jpeg 65A4C0AC-9E08-4D8F-8CA3-C47327CBC7D4.jpeg 8A04819B-4B1B-4B5A-AE69-F063349D59D7.jpeg 49DB990B-48EB-4067-BC5A-CF2A8010CDB1.jpeg 312D891E-3373-4707-8322-2EED531CFC00.jpeg FD63E8A1-BA80-40BC-991F-D8A05C281557.jpeg D7CB3779-17E2-4C5D-A730-63EF7463011C.jpeg 1E18D237-61D5-4F5C-B25B-292FD5862A9E.jpeg 0BBEB92D-D9CE-4DA6-9577-4D6D9C015073.jpeg 48057557-4864-4977-B87C-8ADAF3EDCBA8.jpeg CA211685-77A1-4554-B873-7E10D0A37E4B.jpeg 6ACEE459-9461-40DD-8587-DBE3F249CF20.jpeg
AKNick
Been taking some time to get my scale livery reference points down. Including the beacon! I was able to find the full scale version and scale it down 1:6.3 to find that a 10mm Red diffused LED is perfect. So I got some on the way.
5D30E43B-0421-4B90-984F-61B880C78D91.jpeg A21E41D8-B100-4EEB-AF62-296F532D810F.jpeg B01F870B-FD5D-4031-8984-0D97EC88888F.jpeg CE34564E-D059-49E4-BD07-F853DC9F0A2E.jpeg
one thing I noticed... my scale lines were not lining up. For the blue belly. Turns out the fitting named “strut” mount is actually a gear mount and should be one bulkhead forward. Small discrepancy for the scale look/form/function.
B66FBCB3-D52C-4414-BE83-C6F46A191CAD.jpeg B3CC9E47-E2E0-416B-A226-2CEEC54B1B0C.jpeg
Of course as I’m at work I just so happen to notice N4794C younger sibling N777DH came out to the ramp for a flight, so I snagged a couple photos for reference that I needed.
170591A9-DCB1-48F0-B643-811A9D6099C9.jpeg 89FED414-CC02-4A02-A8D1-AD4A3037BE00.jpeg
