Scale 20cc DHC-2 "Beaver" Kit Build from Moustache Model Works
Attached the bulkhead fittings with a little locktite. Added bulkhead supports, landing gear block, servo mount supports along with drilling, tapping, and wicking some thin CA into the servo thread holes.
MMW provides three options for engine mounts, DLE20 pre-cut beam mount, uncut Beam mount, and a electric motor box. It’s a little unique as the 20cc gas engine is sorta recessed inside the box slightly. I’m guessing this has to do a lot with CG, but either way it’s different than what I’m used to seeing.
I went with the DLE20cc mount as it’s universal to other brands as well (VVRC20).
ACA047B9-6EAA-41E8-8E42-A40CDE7E7028.jpeg EDBDDDC7-8497-482B-B458-1DD2F08F234A.jpeg 3C737C86-EF12-4959-A0C8-EAA4D10217CF.jpeg 220B5AC4-2F26-4D7A-8626-D9D32F9838B5.jpeg 87B6C869-D246-4D82-976A-26B8603FD008.jpeg 0DED0C3B-7BCB-4922-9964-E4A339C9B787.jpeg
Cutting out the option for a gas engine.
B13D6781-D742-4213-89AC-BDD1482B0147.jpeg 08925F01-1DA3-4BD3-A9C9-74B2D6EB77AD.jpeg
Servo mounts
Landing gear block
5A6665AE-A628-4329-A82B-AEEEB29F9FBB.jpeg E5F1EA2B-40C8-48C0-A6D4-A6DF959723C8.jpeg AA14EBA7-ED93-483A-9C3C-7C7C19348471.jpeg 64E6C652-8574-4C37-B3B3-6F0F1CA62001.jpeg
Plywood hotness
Used wood glue on one side, CA on the other.
AF8CD809-06F5-4565-8D36-910F149DE15D.jpeg DE980AAF-65CC-40ED-937A-788D55BCD0A2.jpeg
Using the bulkhead as a guide to glue in the doubler.
57C0F0F1-9CC2-41CA-82BB-46D6BB6EDCE3.jpeg C0C1674F-C311-4860-9439-CDC689FF6B5E.jpeg
Door cover, tacked one side first
Glued the rest
Door liners. Mine were double laser cut, so the fit could have been a little better.
Engine mount
290E54B2-634C-4332-A930-545C686906E3.jpeg 946087BE-B50F-4414-8201-1C55B1FFB0FC.jpeg FF6BA6C2-441E-45FB-B19B-BA6AAE87C50A.jpeg 2864CBB8-D7DE-450A-8BBB-F9EA3E0E7EEC.jpeg 6A7A13DB-3E62-459A-919E-05AA8302574E.jpeg 93904CDB-E40D-4DA5-BF55-68D08CF3AEAF.jpeg F24418A2-F3E2-4A90-957A-A1AEA81F294B.jpeg 7AE18D85-2C9C-4A17-A386-90B770B0E58E.jpeg
Nice work. It really shows that this plane was designed from the ground up in 3D cad, and not cut and hack job from an old drawing.
Now if we can only convince him to in large it to DA 35 size.
HRRC Flyer
Nice going @AKNick ,
I wish I had time to build a kit., but I AM NOT complaining. I'm glad I'm still able to work in this crazy world we are living in at this moment. . . . :big_yes:
Do not glue blkhd #1in.... the pictures show it in, but you cannot slide the fuse skins in to place with the bulkhead glued. I’m going to have to hack it out a bit and improvise. I cannot stress enough to read the manual. Also read the electric box construction as it had important details omitted in the gas box assembly.
2C275448-528A-4B0E-B024-F520CBC4B450.jpeg E9E80D9C-B97F-4FB1-8DD1-340F9EEA5A51.jpeg 6F83A5B1-86BD-46EF-8D08-72DDC45F1EA2.jpeg
On MMW blog on the website there is an addendum to the early kits where the tailwheel steering tube holes in the bulkhead are too small. Sure doesn’t leave a lot of material!
ED59B9CF-AB8E-4E70-A8DD-EA47FCA0C8A9.jpeg 0B7D49B3-4F8A-41D5-B7DE-5DFCB55AEC48.jpeg
David Eichstedt
Planning on a 60cc version some time in the future. I've already scaled up the outer shell in the CAD appropriately. Works out to exactly 50% bigger than the 20cc version.
