Craig77
Hi Guys I thought I would kickstart a thread about Krills new 330LX
I will be receiving one mid January next year. I know theres been a few IMAC guys itching for more info regarding this bird. I will be doing a detailed build thread and share my setup ect.
As it stands I will be using the following
MVVS175ts
JMB rear exit canisters
Hitec 7990 servos all round
Powerbox champion srs with PBus.
secraft hardware.
Mejzlik 31x12EvoL prop.
Finally its available!! get in touch with me if you need anymore info. bellow gives you a good idea what this new machine is all about. should be an awesome IMAC machine!! Iam sure Chief will have some in stock shortly...
The 37% 330LX was designed by KRILL MODEL and by Mr. Gernot Bruckmann . The same like the SC version the new LX looks a near perfect scale model of the popular Extra 330LX by Mr. Walter Extra.
We had with Gernot one major ideas during develop the330LX. We wanted get light airframe and special airplane for precision flying (IMAC, F3M) with not expensive set up (a few servos , enough 150cc also ...etc.). But if you like use 170-200ccm it is ok of course.
Here is some interestion points concerning to LX airframe:
the wings , the rudder , the elevators have central hinged control surfaces
2+2 ileron servo , 1 + 1 elevator servo , 2 rudder servo , 1 trothle servo = need 9 servos only
under motor dome special embossed for better ventilation air from outside the cowl and some more practical tricks
the landing covers (skirts) was integred to the fuselage and on then bottom side used upper cover
the wing and the stab tube of Carbon include
the Clear canopy (light blue effect) glued tu the canopy frame and to be fixed on the fuselage
preinstalled the cowl and the lading gear also
Included in the kit is a tail wheel and two main wheels 120mm
the firewall is set up for 170-190 cc engines. But for an extra charge offer a set up for 4-cylinder engines( see order form)
the firewall with the right trust ready
3 types spinners of spinners are available ( Painted, Carbon or Silver carbon)
the whell pants a the C/F landing gear - very easy assembly !
Is possible use pull/pull or pull/push system. Decision will be by weight of the engine that you will use.
All composite parts include :
all airframe
clear canopy glue to the cabine frame
landing gear
wheel pants
the wing tube of Carbon
the stab joiner tube of Carbon
All hardware include :
2x wheel 120mm
1x tailwheel Extra 41%
wings screws
Rudder tray horn 117mm instaled
Set CNC control horns
stay tuned....
MVVS175ts
secraft hardware.
all airframe
landing gear
wheel pants
2x wheel 120mm
wings screws
stay tuned....
