3dhs 92" edge 540 !!!
I use 2x 2650s in my 60cc planes. The ones I have are Gens Ace Rx/Tx batts. Pretty light and they have both JR connectors and bigger leads that I put my usual Powerpoles on.
For those of you using Lipos in your 92 Edge, which batteries and how many Mah are you using??
On 92" edge #1, I used 2 of then Glacier 2s2200 lipos, and they were good for 6 15minute flights. (Using brushless servos).
On 92" edge #2, I'm using fromeco 2 of the 2600mah relions, planning on the same 6 flights.
Please note that with my identical setup but 7955tg servos on 87" extra, I would charge every 3 flights.
ryan_m
does it matter if i use receiver packs or just regular 2s lipos---- whats the difference
Receiver packs are usually a much lower discharge rate, and theoretically at least, are less damaged when you leave them charged for long periods of time. High discharge lipos don't like to be left at full charge for days/weeks and will develop bad cells faster. Or so it has been explained to me before. I have never seen (or looked for) testing that backs all that up though.
I've heard the same stuff.
Lipos go in for discharge after flying... The Relions I leave in until I need to charge em
Av8r RC
Can anyone put a tape measure to the rudder of the edge and tell me how tall just the rudder is. Not including the tail wheel, just the rudder.
Thanks
The main thing is that you pay a weight penalty for high C rated batteries and they are not needed. Even with your servos fully stalled, you are not pulling more than 10-12 amps across the system in 60cc. Since we are running dual bats with 2k packs you have 4k capacity. This means one is running 3C at fully stalled amp draw. Having 40C packs is simply not needed.
