3DHS Slick eating Savox 1270TG servos
njswede
Today I noticed severe flutter on the tail surfaces on high speed passes. I checked the surfaces and it seems the linkages are tight, but the servos have a significant amount of slop. I think the problem may be that I have single servos on the tail surfaces and while the torque is enough, they may just be too weak from a longevity point of view. (Disclaimer: This is a second hand plane, so I didn't build it with single servos. I would probably have put tandem servos on...)
Any input/ideas?
Robotech
Any input/ideas?
What brand arms are you using? I have had some of the "bling" arms get sloppy.
njswede
I think they're spot-ons. Gotta check the arms. Would be nice if it was just the arms and I didn't have to get new servos.
njswede
Oh, sorry. Forgot to mention that in the title. It's a 104" 3DHS Slick with a DLE120 in it. It's got tons of power and the 27x11 it's swinging makes it pretty fast too.
Husker
Are you running HV? Those servos are pretty weak(comparatively)on 6v.
As the others said...the longer your arm is the more leverage the surface has to fight against the servo. It is like using a breaker bar on your servo.
njswede
Yeah, I'm running them HV. I thinking it's the arms and not the servo. Once I work up the energy to get everything out of the trailer, I will check!
