What I don't get is that, the vyper bype uses M4 bolts for the motor, and so does the 71" slick?
I would think the 71" slick would have bigger bolts?
All the 7x planes use m4. I think that is standard in that size...
I was going to write how I would be getting some new batteries in the spring but I looked at Hobbypartz.com and they had a good price on the Sky LiPo 2650mAh 40C batteries so I bought 2 of them. Their weight is listed as 11.6oz. so with my set up the system will still give a respectable 185 watts/lb.
Freddy
Hi Freddy. Where on the battery tray are you placing these bats to get the CG?
Lance
has anyone found any alternatives to the hitec 85/5085 servos yet? I saw a futaba that may do the trick, but cant really find anything else
I have just received the 2650's and have not yet even changed the connectors out to the Dean's yet, let alone flown them in my Byper. However, with my setup the 3300's and the 2200's that I have are centered on the battery tray and that seems to be about right. I only have 4 flights on my plane and I probably need to do some fine tuning with battery placement but it feels pretty close.
Freddy
