48" Extra 330 EPP
Bushwacker
3DRCF Moderator
Hey fella's how do you think this little guy would perform with these components and I only ask because I've never had this kind of foamy balsa type bird in fact this would be only the second foamy I've ever had.
EF Torque 2814/820
Airboss 45A Esc
4S 2700mAh LiPo battery
Hitec HS 5070/5065 servos
Bloosee
EF Torque 2814/820
Airboss 45A Esc
Should work fine, although the 4S 2700 will be much too heavy. I use 3S 2650's and I feel they are at the upper end as far as weight for 3D flying, it's light and floaty on 3S 2200's. For comparison sake, I use 4S 2700's in the Aerobeez 55 Edge, which is actually a MUCH larger airplane.
-Brian
