For Sale 60cc redwingrc Extra 330sc
BrandonD
I have here an extra 330sc from redwingrc. I used this airframe for under a year and i have moved on from it. The only reason this plane is not completely ready to fly is because the wings are compromised, They can be fixed but it would require re-doing covering. The sheeting inside the leading edge of the wing is pulling away from the spar inside the wing. Other than that everything on this plane is ready to go, the canopy has been cracked in the back and fixed with glue and was flown 10+ times with the canopy. The stabs are in good condition but could use an iron to level the covering. The fuselage and rudder are all in good condition except that the gear has been ripped out but it has been replaced with a new gear block, and new gear. If the gear is going to break it will definitely be taking the rest of the plane with it! The fuselage has aeroworks 60cc freestyle 260 aluminum gear on it making it stronger than ever! The firewall is in good condition but does have some oil splatter considering the plane was used! The cowl has been cut for a dle-61 and does have some stress cracks because it also was used! It has a ringed cowl on it as well!
Shipping is an available option!
$300 shipping at buyers expense.
