Aeroworks 150cc Yak 55M ARF QB
Discussion in 'Manufacturer's Announcements and Discussions' started by 3dmike, Jun 22, 2015.
  1. 3dmike
    3dmike 640cc Uber Pimp
    Guys check out this new Airframe from Aeroworks! Wow this is a looker and sure to be an awesome performer! This is due to arrive in the next 3 weeks so get your order in now!!!
    Link: http://www.aero-works.net/product/150cc-yak-55m-arf-qb/
    [h=2]150cc Yak 55M ARF QB[/h]Aeroworks is proud to add the 150cc Yak 55M ARF QB to their line of Quick Build Series Aircraft. The Quick Build (QB) Series is top quality in both design and performance that has set a new standard for ARF aircraft. Designed with the customer in mind to provide the highest quality, light weight construction and fastest build time possible.
    The 150cc Yak 55M was designed to be the best looking and best performing Yak to date. This aircraft requires minimal mixing and aileron differential creating the truest flying Yak EVER! The Yak 55M has unbeatable stability and precision flight characteristics and is certain to please both the beginner as well as the advanced competitor. Designed for both Precision and 3D Style flying this plane is sure to out perform all other aircraft.
    FEATURING
    Strong Light Weight Construction
    Professionally Covered in Ultracoteâ„¢
    Pre-Mounted and Tinted Canopy Hatch Assembly
    Pre-Mounted Fiberglass Cowl and Wheel Spats
    Flush Fit Cowling with No External Mounting Bolts
    Canister and Pipe Ready
    Pre-Installed Engine Baffling
    Pre-Installed and Fuel Proofed Engine Box
    Laser Marked Firewall for DA and DLE Engines
    Universal Engine Mounting Template Provided
    Two Servo Wing
    One Servo Elevator
    Carbon Reinforced Wing Spar Increases Wing Strength
    Large Control Surfaces Beveled for Maximum Throw
    Pre-Installed Slot Style Hinges
    Carbon Fiber Wing Tube
    Carbon Fiber Stab Tubes
    Carbon Fiber Landing Gear
    Carbon Fiber Tail Wheel
    Complete High Quality SAE Hardware Package Included
    Adjustable Pushrods with Centering Nut
    Complete and Detailed Instruction Manual
    12 to 14 Hours Assembly Time
    Optional Accessories:
    Dash Panel
    Wing and Stab Bag Set
    SPECIFICATIONS
    Wing Span 122 Inches
    Wing Area 2775 Square Inches
    Fuselage Length 109.5 Inches (Rudder to Front of Cowl)
    Fuselage Length 115.5 Inches (Rudder to Front of Spinner)
    Cowl Width 14 Inches
    Weight 38 to 40 Pounds
    Engine 150cc-200cc Gas
    Spinner Size 5 Inches
    Radio 6 Channels Minimum
    Recommended Servos:
    Throttle: Hitec HS-5625MG
    Aileron: Hitec HS-7955TG (Quantity 4)
    Elevator: Hitec HS-7955TG (Quantity 2)
    Rudder: Hitec HS-7955TG (Quantity 3)
    *See Manual for Minimum Operating Speed - Torque Output
  2. AeroWorks
    AeroWorks GSN Sponsor Tier 1
    155
    117
    43
    Hello Mike,
    Thanks for the post the planes are In Stock and shipping!
    Thanks,
    Rocco
  3. 3dmike
    Sweet!!! Thanks for update Rocco!
  4. AeroWorks
    155
    117
    43
    New video Andrew Grant flying the Aeroworks 150cc Yak 55M QB!
    [video=youtube;8_hTQ4EcPts]https://www.youtube.com/watch?v=8_hTQ4EcPts[/video]
  5. AeroWorks
    155
    117
    43
    Here's Joe Hunt’s slideshow of the photoshoot with Kylee and the 150cc Yak55M don’t miss the bonus footage at the end.
    https://www.youtube.com/watch?t=1&v=5EqzNT_3x1I
    [video=youtube;5EqzNT_3x1I]https://www.youtube.com/watch?t=1&v=5EqzNT_3x1I[/video]
  6. wfahey415
    wfahey415 3DRCF Moderator
    +1 :thumbup:
  7. AeroWorks
    155
    117
    43
    Here’s another great 150cc Yak55M video from Joe Hunt.
    Thanks Joe!
    [video=youtube;Vnn7Elh2uOQ]https://www.youtube.com/watch?v= Vnn7Elh2uOQ[/video]
  8. Bushwacker
    Bushwacker 3DRCF Moderator
    Yeah think I would have to rate both a +10
    The model and the plane. :thumbup:
  9. extra260
    extra260 30cc
    11
    1
    3
    so CA
    what there
    There was a plane in that video???? Beautiful both I fly a 55cc yak 55lm and is one of my best planes.
