SOLD! Brison 6.4 (105cc) with CH ignition and solo prop $450
Pancake
Brison 6.4, with exhaust, CH ignition, Walbro carb, and matched 2 blade Solo adjustable pitch prop. Exhaust is tapped for smoke. Perfect for scale applications, with long exhaust tubes for big round cowls.
I removed this from a barely flown 1/3 Waco that I am putting a larger engine into. On close inspection, this engine is not even close to being broken in. I has run maybe 3 times in it's life. The plugs are barely discolored, and you can still see aluminum shine on the piston tops and inside the exhaust pipes. From what I can tell it's never seen Ethanol fuel as all the Tygon in the airplane was still totally flexible (like new). When people say "They don't build em like they used to" they might as well be talking about this engine! Strong, light, and made to last.
Engine retailed for $1,400.00, and the prop is at least $250.00 new. That's a $1,650.00 value for $450!!!
Plaincrash
Looking for twin for BUSA 1/3 SuperCub. I'll have to check cowl width to see if it will fit. I believe all I have is about 10". Thanks for rapid reply. Ray
Plaincrash
I am looking for a twin for a BUSA 1/3 SuperCub. I will have to check the cowl. I think I only have about 10". Thanks for the rapid reply. Ray
les2097
Hi,
I'm interested in your Brison 6.4 engine... trouble is that I have too many engines in boxes now... Would you be interested in a trade...?
I have a new, never run BME 50cc engine; a Sachs 4.2ci never run needs ignition installed; and a Homelite conversion 30cc Walbro carb, Bennett muffler runs great...
I'll trade my three engines for your Brison 6.4 engine...
Please let me know.
Thanks
Larry
les2097@gmail.com
Trent Wilhelm
Hi,
I seen you ad for this Bison 6.4 engine and would like to purchase it from you, can you please contact me or let me know how to get in touch with you.
Thanks
Trent
