We have the parts for your ideas, and we are always adding to our line-up! Below are some of the newest releases from Hitec that you'll be able to find at ServoCity within a short time.
Hitec Battery Buzzer:
Features:
High Pitch Warning Sound
Input Voltage: 7.4 ~ 16.8 volts
Battery Type: 2 ~ 4S LiPo
LED Status Indicator
Voltage Select: 3.2V/3.3V/3.4V/3.5V ±0.05V
Net Weight: 11g
Dimension: 1.97 x 1.10 x .49 in.
Introducing Hitec’s Battery Buzzer - their compact, convenient, low battery voltage alarm. No longer do you need to wonder about your flight pack condition. The Battery Buzzer warns you when you are getting close to the end of your flight and it is time to land. With a programmable voltage threshold, you decide how much advance warning you want when the alarm sounds. Not only does it protect your model from unexpected off-field landings, the Battery Buzzer also protects your battery from over-discharge, maximizing your investment. Both inexpensive and light weight, the Hitec Battery Buzzer is a must-have accessory for all your electric models.
Hitec HS-40 & HS-53 Servos:
HS-40: Economical, Nano, Nylon Gear Analog Servo
Our research department and engineers work tirelessly at developing economical servo technology that outperforms the competition and the new HS-40 nano analog servo delivers just that. With a three-pole cored motor and resilient nylon gears, this affordable servo is a dream come true for micro aircraft, sailplane and helicopter pilots. Slightly larger than the popular HS-35HD with an operating range of 4.8 to 6.0 volts, the HS-40 is a solid performer that is easy on your wallet!
Motor Type: 3 Pole
Bearing Type: None
Speed (4.8V/6.0V): 0.12 / 0.10
Torque oz./in. (4.8V/6.0V): 8.4 / 10.5
Torque kg./cm. (4.8V/6.0V): 0.6 / 0.75
Size in Inches: 0.79 x 0.34 x 0.67
Size in Millimeters: 20 x 8.6 x 17
Weight ounces: 0.17
Weight grams: 4.8
HS-53: Super-Economy Feather, Nylon Gear Analog Servo
The HS-53 is our newest economical, feather servo designed to compete head to head with the influx of low cost servos while still maintaining Hitec’s renowned quality. Designed with a durable nylon gear train and an efficient three-pole cored motor, this light-weight servo is a terrific fit for small power planes and gliders. Priced right, it is sure to become a universal favorite!
Motor Type: 3 Pole
Bearing Type: None
Speed (4.8V/6.0V): 0.16 / 0.13
Torque oz./in. (4.8V/6.0V): 16.7 / 20.8
Torque kg./cm. (4.8V/6.0V): 1.2 / 1.5
Size in Inches: 1.12 x 0.46 x 0.95
Size in Millimeters: 28.6 x 11.6 x 24.1
Weight ounces: 0.28
Weight grams: 8.0
Hitec Brushless Servos (HS-9465SH, HS-9475SH, HS-9485SH):
Pro level hobbyists demand the power and precision found in our triple threat HSB-94XX servos. Each one is designed with our durable steel gears and impressive Neu Castle brushless motors with the HSB-9465SH bringing lightning speed, the HSB-9475SH delivering multipurpose performance, and the
HSB-9485SH offering high torque performance!
Stay up-to-date on new releases by visiting our "New Products" page:
http://www.servocity.com/html/new_products.html
