For Sale DLA 56 Gas Engine NEW IN THE BOX $275 shipped
Go4it
Purchased from Milehighrc $330 never built the plane it was for. So,I traded the plane and no longer need the motor.
Specifications:
Power: 5.6HP/7600RPM
Idle speed:1400rpm/min.
15kg/100M Alltitude
13kg/1800M Altitude
Propeller: 22×8,22×10, 23×8, 23×10
Spark Plug: Iridium CM6
Exhaust Amount: 56cm3
Diameter & stroke: 45mm×35mm
Compression ratio: 7.8:1
Lubrication Ratio:30:1(break in), 40:1
Weight: Main Engine:1290g, Exhaust Pipe:115g, Ignition:120g
