Dual Rates Set-up
Discussion in 'Radio Programming Questions' started by Roger Chamberlain, May 4, 2020.
  1. Roger Chamberlain
    Roger Chamberlain GSN Sponsor Tier 1
    31
    61
    18
    Az
    I have a question about dual rate set-up.
    1. I do not know how yet to fly 3D.
    2. I mostly fly IMAC style. I look at the current sequence and do my best to copy. Currently Basic & Sportsman.
    This is my question when setting up ones radio. Do you guys when setting the low rates set them all, Meaning the control surfaces to ONE TOGGLE SWITCH on the radio?
    Thanks in advance
    Roger
  2. BalsaDust
    BalsaDust Moderator
    Its all personal preference. I have a couple club members that like to set each control surface up to its own rates switch but I personally do not like that. I believe in a more simplistic approach and have them all on a single 3 position switch on the right side of the radio. Really this holds true with just about everything in a radio setup though. I know a few that for 3D run a ton of expo on the rudder. For me I hate having expo in the rudder. Not sure why as I run 20-30 percent on the other surfaces but the rudder I just like it to have a raw feel I reckon.
    Hope this helps.
    Roger Chamberlain likes this.
  3. dhal22
    dhal22 GSN Sponsor Tier 1
    I run triple rates on 1 switch, simple enough for me.
    Roger Chamberlain and Herman Syx like this.
  4. Snoopy1
    Snoopy1 640cc Uber Pimp
    6,301
    8,599
    113
    Canada
    Run three switch’s at three rates. Fly at windy location.
  5. Roger Chamberlain
    31
    61
    18
    Az
    Thank you very much.
    Roger
  6. WMcNabb
    WMcNabb 150cc
    1,672
    3,402
    113
    TN, USA
    I’ve learned only a fraction of what my transmitters could be programmed to do.
    I fly Spektrum and use Flight Modes for the rates on both my DX9 and DX18.
    Between two switches, one on each side of the radio, I have access to five flight modes. I learned this while playing around with an aerobatic Cessna 170. Flight modes were as follows: full span ailerons, flaps and ailerons, crow, low throws, and high throws. Each flight mode sets the throws of the surfaces and the corresponding amount of expo.
  7. AKNick
    AKNick 640cc Uber Pimp
    2,549
    4,124
    113
    Alaska
    On my 18SZ I run all my rates on a single three position switch (SD). The position closest to me is normal, next up is dual rates, and if I want a third rate I have to create a condition in the radio that I name 3D EXTREME rates. LOL. I have found myself moving away from triple rates and leaving the furthest switch active as dual rates as well. Low rates after the maiden are adjusted to my liking for sunday flying, then the next rate as give her all shes got (Or MFGR recommendation) and dial down/up to how the plane best performs for me.
    Roger Chamberlain and WMcNabb like this.
  8. Roger Chamberlain
    31
    61
    18
    Az
    Thank you all. My weekend is going to be set up messing around with Dual Rate configs.... I like it. Thank you everyone for giving me a new way to look at Radio set up.
    Roger
    WMcNabb likes this.
