bobzilla
Fromeco 6v HEAVY DUTY adjustable regulators (4 avail)
I have four (4) Fromeco 6v regulators with I am no longer using. All are excellent condition, have been checked and output 6v. They are adjustable. Use with LI-ION 7.2-7.4v or 2-s LIPO. Extra heavy duty wires and deans on in/out.
$25 ea shipped conus.
From manual:
VOLTAGE ADJUSTMENT:
Adjusting the output Voltage of your new Super Regulated
Reliaswitch or Regulator is easy and can be done a number of ways.
First thing you will notice is two (2) pins sticking out of
the right side of your new Switch or Regulator. These
pins are used to adjust the output voltage of your unit.
These pins are nothing more than shorting pins that complete a circuit. When this circuit is completed the VDC either goes up or down.
We have designed this circuit to go
no lower than 5.5VDC and no higher than 7.2VDC. Any
**Conductive**metal object such as a screwdriver can be
used to adjust Voltage up or down.
From manual:
VOLTAGE ADJUSTMENT:
