Unbalanced
Woot woot! Free plane? Where do I sign up?
Yep, that would make an awesome first all new giant scale. Feeling an upgrade coming my way.Win a Hanger 9 Extra 300X
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
