Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
Lavell
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
Thanks for the chance to win
rcpilot_2000
Foam-Core Wings
Painted Hatch
rcpilot_2000
Foam-Core Wings
Painted Hatch
I'm in
rcbobp
I'm in, but after seeing Donnie's offer to donate it to Youth Masters if he wins, I'd feel like a louse if I kept it.....so I'll second that donation!
Status
