Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
Kevin-K
I taketh this Extra to have and to hold, from this day forward, for better, for worse, for richer, for poorer, in sickness and in health, to love and to cherish, till death do us part.:yesss:
bob_nj
I owned the yellow Hangar 9 Extra a few years back and it flew great.
Hope this one flies half as good...
Take care
Bob
Ronald Thomas
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
This is AMAZING! Giving away a rocket ship like this...I am in!!!
Status
