Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
Xtreme_Power_RCS
Lots to like about this ARF, I am dying to see the foam core wing up close and personnel. Can't understand why more folks aren't signing up for this contest, 77 days and only 490 post? This must be one of the best kept secrets in the hobby.
To bad, they did not decide to make their new plane a Yak 54!
Remember, Ol' Bearly sez,
"A bad day at the flying field is better
than a good day on a golf course!"
and
"If it an't round its square,
FLY A YAK!"
Hope to see you at the flying field,
BNK​
I agree, this should be HUGE right now! Please Share to all your R/C buddies! Have them sign up and comment right here for there chance to win!
Sounds like I need to make room for a 120CC Extra 300X in my hanger. Sorry guys and gals, this one has my name on it. Better luck next time :cool:
Umm....Mark!!! I thought I told you standing too close to your exhaust pipes will cause temporary memory loss combined with delusions of grandeur. I thought I made it quite clear who would be the proud owner of this awesome plane.
Johnntay
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
So would love to have this plane in my hanger
Status
