Darren Rust
I'm selling a lightly used Hacker Q80-8M Brushless Motor with two sets of aluminum stand-offs, 50mm and 90mm. The 90mm, will fit a 3DHS 92" Edge 540, and the 50mm will fit the Extreme Flight 91" Extra 300 EXP. This motor is in pristine condition and looks brand new! If you need batteries to power this monster, I have 4-Pulse 5500mAh 6S lipos with very low cycles, including 2-5000mAh 6S batts that have zero cycles! Contact me for information! Buyer pays shipping.
Weight: 980.00 grams
Shaft Diameter: 10.00 mm
Shaft Length: 30.0000 mm
kV: 210
Idle Current: 1.80 Amps
Operating Current: 65 Amps
Peak Current: 125 Amps
Peak Watts: 5500
Peak Amps: 0.0000
Resistance: 0.0150 ohms
Poles: 28
Orientation: Out
Motor Diameter: 88.00 mm
Motor Length: 67.00 mm
kV: 210
Peak Watts: 5500
Peak Amps: 0.0000
Poles: 28
Orientation: Out
