Discussion Help to find a true 150 cc 3D plane.
Discussion in 'Giant / Scale RC General Discussions' started by Snoopy1, Jun 24, 2019.
  1. Snoopy1
    Snoopy1 640cc Uber Pimp
    5,664
    7,964
    113
    Canada
    Looked at all of them except Dalton do not know them and have never see one of there planes up close, it is kit if I am not mistaken. Will look them up.
    acerc likes this.
  2. Alky6
    Alky6 150cc
    Dalton is available from JTEC. JTEC bought them a year or so ago...
  3. Snoopy1
    5,664
    7,964
    113
    Canada
    Yes you are correct after going through there web sight I cam to that conclusion. Make some nice stuff but right now AJ is the leading candidate.
    Alky6 likes this.
  4. Alky6
    Alky6 150cc
    After seeing them fly and if the interest is an ARF, that is where I would land (AJ Aircraft) as well. Lots of work for a 3D machine (that has a higher likelihood of a short life) to build a kit.
    AKNick likes this.
  5. Snoopy1
    5,664
    7,964
    113
    Canada
    You are right about that 3D planes do not have a long life span. I have old pattern plans that 10 years and older and some very nice sport planes that are 16 years old but since I got into 3D have had a plane last much longer than season without some sort ground adjustment. Have already destroyed one 20 cc plane this season, you are always pushing the limit 10 ft of the ground
    AKNick likes this.
  6. dhal22
    dhal22 GSN Sponsor Tier 1
    Can't the H9 3.1m Sukhoi be brought in under 40 lbs? I believe I've heard of 38 lbs.
    Snoopy1 likes this.
  7. Xpress
    Xpress GSN Sponsor Tier 1
    Andrew designed the 115 Laser for a 150, it flies amazing on that engine.
  8. Snoopy1
    5,664
    7,964
    113
    Canada
    You are correct great plane fly great and are very well built, but a person about an hour from has one built it and installed a DA 150 L it was in the plane for one weekend and replaced with ZDZ 195 I believe and now loves the plane. And not only him but i believe that you also have larger engine in the plane.
    What is the weight of your plane standing on the runway ready to take off.
  9. Xpress
    39lb and change with a ZDZ180. I didn't have a DA150L hanging around otherwise I woulda chucked that on the nose and saved the 180 for a much larger airplane. The 150 on the 115 does fly pretty damn amazing though and I wouldn't be searching for more power. As is it has an overabundance of power.
    Snoopy1 and dhal22 like this.
  10. Snoopy1
    5,664
    7,964
    113
    Canada
    Thanks for that still looking and I believe that 115 will be my next plane for the 150
