HS-7954 alternatives
Flyingjon
Good evening to all! I've been going over my AW Freestyle 260 30cc and considering doing a rudder servo update. I'm running a 5585 in it now, but I'm considering a 7954. It gets pretty hard use and I'm running a 2s lips setup so I need high voltage. Is there a different servo I should consider?
Thanks to all for the helpful information on this site!
Jonathan
mnfatboy
If you are looking to stay Hitec the HS-7955 is a great servo with titanium gear. Savox SV-1270TG is great servo for that size air frame and comes in with a bit more torque at about 487. I have run the 7954, 7955, the Savox in that size air frame with great success. I don't think you could go wrong with either one.
Flyingjon
Thanks for the suggestions guys. The way I understand it, the Savox and MKS have a different number of splines on the output shaft. I may stick with Hitec to keep the same SWB arm.
mnfatboy
You are correct. MKS and Savox use 25T Futaba splines. Hitec is 24T except for the HS-8xxx or HSB-9xxx series servos which use 25T.
