jtec/radiowave
By the way, You're doing a hell of a build!!
Al
Al
Thank you... it's greatly appreciated. I totally get needing the break. Glad you had the opportunity to do so. I will gladly take time to give you my feedback on the road blocks I ran into. Granted, typically a builder "should" have at least an idea of how to proceed with certain building techniques, there also remains a certain degree of direction that one could use periodically to achieve the results that are intended. Unfortunately, (and not to my credit) I can be very "anal" and o.c.d.! . I fear I also get frustrated too easily. "Some" simple steps were overlooked in the manual. But not to the degree that it could not be handled. After this thing is done, I will relax and offer a few points that "may" assist others in this build endeavour.By the way, You're doing a hell of a build!!
Al
Never thought I would have one myself. But I think I've fallen in love with this one. Lolgood job on the build. i cant wait to hear how it flys. i want a big bipe one day.
Well now I have gone and done it. I conjured up a recipe for scratching together some wing tips for the Pitts. Mmmm....tasty. LOL. Seriously, The weather here has been phenomenally perfect and I should have been flying. Can you all believe it? Sunny clear blue skies, High 60's and 2 mph winds gusting to 5. And I am building? I really need my head examined. Oh yeah, OCD Rob...Lets talk about those wing tips. I will fly tomorrow.
I really was not sure what I wanted or how to go about it. I knew I needed to make the wing tips strong but light. I had an idea from the photos I have looked at and @Bipeguy03 35 center Pitts. Ah ha...that should be fairly easy to duplicate. Ha, five hours later I have one half of one wing tip built. I figured a 3/32" sheet in the center of the wing tip rib would set my size and shape. Since the bays at the ends of the wings are roughly 3.5", I started with that and adjusted from there. My final width was 3" from wing tip rib to the end of the wing tip. I started with the lower bottom right wing first just in case I messed up, any mistakes would not be as easily noticeable as if it were on the top of the wing. Anyway, I drew out a patten of what I felt was pretty close to accurate, then traced that shape on to the sheet of balsa that will be the center of the wing tip. Drawing a straight line right through the middle of the wing tip rib would be the placement of the balsa sheet. I intentionally left that sheet just a smidgen short at the trailing edge of the aileron as the sheeting that will lay over the top and the bottom of the tip would need to have room to come together without leaving a "bulge".
View attachment 90983 View attachment 90984 View attachment 90985
I then drew out a curved flat rib for the "near" border of the balsa sheet from a piece of scrap 1/8" balsa sheeting. Using a 1/8" by 1/4" balsa strip, I then glued that to the exterior edge of the wing tip rib as a mounting stringer for the top sheeting.
View attachment 90986 View attachment 90987 View attachment 90988 View attachment 90989
Next I used 1/4" by 3/32" balsa strips to make the sheeting supports that will extend from the wing tip rib to the edges of the new wing tip. (I know, I know....Confusing huh?....wing tip rib for the wing tip?) I supported these with small extension pieces from the underside of the balsa stringer that runs the length from leading edge to trailing edge. Bringing them down to meet up with the flat rib that goes around the border of the new wing tip.
View attachment 90991 View attachment 90992 View attachment 90993
Once I had the ribs/supports in place... I lightly sanded a bevel in each one to allow the sheeting that will go on top of them the ability to lay flat when glued in place. Before doing so however, I decided to do a test fit of covering minus the sheeting. Just to see what it would look like. Had I designed the wing tip with the thought in mind of using covering only, it probably would have looked better. Ah well, off with the covering and on with the sheeting.
View attachment 90994 View attachment 90995 View attachment 90996
I made the wing tip skins from 1/16" balsa sheets. I really felt that using anything other than that would be a waste and add more weight than I wanted. Plus, it should be plenty strong enough. Once glue was applied to all the contact points for the skin, the sheets were placed into position then clamped down. Once again, those clothes pins came in pretty handy.
View attachment 90997 View attachment 90998
An ice cold Pepsi and a Canadian Bacon and Pineapple Pizza later, the glue was cured enough that I could remove the clothes pins to inspect the new wing tip. A little light sanding and very minor adjustments to the shape and lookie lookie. Not too shabby....
View attachment 90999 View attachment 91000
It is a little difficult to see the curvature of the wing tip at this point. But from what I could tell, it is pretty close to the way it is supposed to be. Once the other side is completed, I will do a final sanding then cut the aileron from the wing and finish up the hinge line. It won't be long and this wing will be 100% ready for covering. Now if I only had a definite decision for a scheme. LOL.
What do you all think? It is not too late to alter this wingtip. Any of you think I need to sand a little more "radius" on the wingtip? Also, with the added 3" to each wing tip, this will bring the overall wingspan to 78". What do you all think? An extra 6" wingspan make any difference in flight characteristics?
Sweetness....thanks so much. I was hoping (and meant to ask if you would mind) you post a photo of the wing tip. I really appreciate it. I am going to go back and sand a little more radius before moving on to the next wingtip.Looks pretty good! The tips on my 35% have a little more radius at the leading edge but yours looks pretty close! As for how they will effect the way it flies, I don't think they will make any difference, they don't add any lift or drag to speak of they are just kind of good looking baggage
I grabbed a picture of one of my 35% wing tips for ya.
Hey David, thanks for your suggestion. Truth be known, I actually considered using ply and then cutting "lightening" holes in it. Two reasons I chose the balsa over the ply is, one: when balsa structure comes together at a glue joint, it is nearly as strong as ply. I am usually quite anal how my planes are handled so I really didn't feel the strength would be an issue. I was more mindfull of watching the weight. Which was reason number two. Plus cutting the same holes to keep the weight off the wingtips, (which really wouldn't have been much) it would have been more work. Odd as it my seem, if I ever get a tiny ding in any of my airframes, it is usually the rudder. Bottom side. (Hmmm, imagine that!)Hey Rob, what's wrong with you? The weather was so nice here, even I took my Kaos out the field yesterday for couple of flights. . . . .
I certainly have no business telling you or anyone else how to build anything, but since you asked I will offer my suggestion (albeit a little too late). I would have used a piece of plywood in the middle of the tip for some extra ding resistance. You could have cut out the middle to save weight or you could have left it on since I don't think your 3Dub would ever know the difference.
Build on Buddy, AFTER you go flying today. . . .![]()
