IMAC FANATIC
40% happier than most folks.
So heres the piece im working on, windex area liberally, bith sides, rub it in with fingers to ensure 100% coverage with Monokote, lay the piece and smooth with hand first. Wait 5-10 min to let chemicals kick . Start with 1/16" balsa squeegee, push outwards and remove most of windex, wait 5 more minutes.
Use balsa 1/2" squeegee and work out more air and water , the covering will begin to feel soft by now, go over and over and over the layer until your happy and then do it some more.
Finally use the plastic squeege and work out the remaining problem areas, be prepared to do this till your bored. The less pimples and air the better.
Thats all for tonight. Let rest and dry till tomorrow, turn the heat up in the roo if you can or want to. Better than 70° is fine.
