Kyosho ReadySet 1/18 G-Zero Drone Racer
Discussion in 'Giant Scale News' started by GSNadmin, Feb 28, 2017.
  1. GSNadmin
    GSNadmin Staff Member
    [​IMG] [​IMG] [​IMG]
    From Kyosho:
    DRONE RACER glides above the ground with pistol-grip transmitter control.
    Unlike existing drones that are difficult to control, the sensational DRONE RACER is controlled like an R/C car with a pistol-grip transmitter. Takeoff and auto-hover with one-touch control using ultrasonic sensors that remove the frustration of learning complicated flying techniques. Intermediate and Beginner mode speed settings (Easy mode / Active mode) are available so you can experience the fun of drone flying at your own pace.
    Control with a pistol-grip R/C system.
    Includes the latest 2.4GHz Syncro KT-231P pistol-grip transmitter featuring advanced aircraft-like instrument panel. Flying height adjustment switch is installed on the base of the transmitter grip.
    Readyset includes everything you need. Open the package then charge the battery to start flying.
    Dogfight only 35cm above the ground. Speeds over the ground just like a hoverboard. Newly developed drone technology.
    The DRONE RACER is equipped with advanced ultrasonic sensors, 6-axis gyroscope (3-axis angle speed sensors, 3-axis acceleration sensors), barometric pressure sensor and four fast response mini coreless motors. Speed switching function provides a choice between “Easy Mode” and “Active Mode” and delivers direct intuitive flight control.
    Low Height Flying Control
    Altitude is automatically maintained with ultrasonic and barometric pressure sensors. Altitude setting of 35cm or 60cm can be selected with a switch on the R/C system and one-touch control is used for takeoff, hovering and landing. Some people may feel frustrated in learning drone flying techniques. Kyosho’s newly developed technology*(patent pending) removes these barriers so anyone can enjoy the fun of flying drones. *according to Kyosho research
    Flies over any surface, even over water. Maintains constant altitude of 13inches (23 inches) using ultrasonic sensors.
    Variable Propeller Unit Structure
    H-type chassis with split upper and lower sections and left-right propellers connected on one propeller arm allow the propeller unit angle to be changed between: 0°, 10°, 20°. Use more stability (0°/ max speed : 30km/h) or more speed (20°/ max speed : 34.5km/h) as a racing weapon.
    Exterior
    Fast, beautiful and more powerful. Sophisticated masterworks.
    Model lineup features two body style designs, the G-ZERO and ZEPHYR, which are based on a futuristic impression of car with the narrow form and rear wings associated with formula racing cars.
    Bright LEDs light up the fuselage. LEDs can be used as drone identifiers when racing.
    Full color LED installed on front propeller units allows a selection from 6 colors. You can choose your favorite luminescent color to use as an identifier when racing.
    Features rear LED with color indicator of propeller status.
    Red : flashing indicates low battery warning, when lit indicates safety function is released & can operate as tail lamp
    Yellow : transmitter not connected = RADIO EMERGENCY STOP
    Green: flashing indicates detecting horizontal, when lit indicates ready to takeoff and safety function is activated
    Blue : gyro calibration in progress
    [​IMG]
    For easy identification the front mask features 2 bright white LEDs and the tail features a red LED.
    1. Infrared sensor(Lap counter)
    2. LED color change/Calibration switch
    3. Propeller angle change/Horizontal adjustment switch
    4. SV external power port
    5. Extension LED port
    6. Micro USB port
    Infinite Possibilities
    DRONE RACER SETTING MANAGER
    DRONE RACER can connect to your (Windows) computer with the included USB cable to adjust flight settings. In addition, an optional cable can also be used to connect to an Android terminal with a USB host function to adjust settings. Download the free (DRONE RACER SETTING MANAGER) to adjust to your favorite setting and turn up the volume of fun.
    KIT CONTENTS:
    Fuselage
    USB auto cut charger
    Pinion gear replacement tool (combination binding stick)
    3.7V-1000mAh Li-Po battery
    Arm holder (10°, 20°)
    USB cable
    Spare propeller set (for one drone)
    Quick start guide
    Instruction manual
    REQUIRED FOR OPERATION:
    4 x AA size batteries for transmitter
    Computer with USB port (for charging) or USB power charger (if output is more than 2A, full charge can be complete within one hour)
    TECHNICAL DATA:
    Length: 302mm (with guard)
    Width: 300mm (with guard)
    Height: 65mm
    Gear Ratio: 5 : 1
    Weight: 130g approx.
    Motor: 8.5mm coreless
    Battery: 3.7V-1000mAh LiPo
    Propeller: D5 X P4
    Flight Time: 10 min. approx.
    Charging Time: 1-2 hours (Depending on USB power output)
    Max Speed: 30km/h approx. (normal spec) 34.5km/h approx.(with 20° propeller angle)
    #20571R-B – $219.99
    Visit KyoshoAmerica.com
    See more posts about Kyosho
