My new 72" 3DHS Extra 330
robj
And Expo!! I maidened my87 with no expo. It was on the other switch and in all the drama I missed it. Of course when checking for proper movements one usually doesn't check for expo. But I got it down ok and reset it.
robj
Yea...my spotter said..."looks real twitchy, did you put in expo?" me...yes I did...but it doesn't have any :sadface:
Stevo
Hi Rc girl,
I noticed you are using the specktrum withe remote receiver. Not sure if it was suggested or not, Try changing out the wire between the receiver and the remote receiver.
Then rebind and check it again. I had a wire that was bad give me similar symptoms. Its worth a shot.
Steve
RC Girl
I charged the life batts that power my servos.. it's working fine now. I'm gonna do a range check later and make sure everything's working. I hope the batteries were the problem and not something expensive or hard to fix
Never thought about that, I remember sometimes if battery voltage was low it could cause some issues. Not usually the case, but a good thing to check. Check your batteries every flight!
Thanks
Brian
Jwmav528
LiFe battery voltages can be misleading. The discharge curve is so flat that my Hyperion battery checker sometimes has trouble translating the voltage to a remaining pack capacity. It's always good to recharge after a flight or two and track the mAh being restored to determine the amount of battery that gets used in a flight and determine how many flights you can get from there. This is because LiFe chemistry batteries have an immediate drop to 3.3 V/cell where they sit until they are mostly discharged.
