Scale Need advice on trailing edge aileron & flap bow on BUSA 1/3 Super Cub
Discussion in 'Giant / Scale Scratch and Kit Build Threads' started by Dave1953, Feb 15, 2019.
  1. OK, I will try that and see what happens.
  2. Ken Marlor
    Ken Marlor New to GSN!
    For a man with poor vision that looks like an excellent build you've done there, regardless of a little bow
  3. Bartman
    Bartman Defender of the Noob!
    I agree with Ken! Is the spar for the aileron bent also or just the trailing edge? It might be built into the aileron by the joining of the two sheets at the trailing edge, can you slice off the top trailing edge sheet, see if it straightens out, and then do it again with some shims to correct it as the second sheet is being attached?
