NEW CELL METER and NEW POWER SUPPLY IN STOCK!
Rick dazzler
Hey guys.. We have your fix if buying A123's from use or for your lipo's. it is a digital balancing and cell milli-volt/capacity meter!
We also have a new power supply. for our charger line.
LIPO/A123/Nicd/Nimh Battery Capacity/Millivolt Checker And Tester/Balancer. WORKS GREAT FOR A123'S!
If you fly electric's you need this! If you USE A123's and want to see what you got left before that next flight YOU REALLY need this!
You can check voltage, % left in battery, and cell voltage/balance
ALSO Blance charge and discharge your a123/life/lipo packs!
check batteries: Lipo/Li-fe/li-ion: 2-7cells Nicd/NiMh: 4-7 cells
12 VOLT 16 AMP Power Supply 230 WATT Power Suppy for Charger
imaxRC B20 Pro 14V 16A Universal Power Supply / AC Adapter
[IMAXRC-B20]
IMAX B20 PRO AC adapter will transform AC 100-240V into DC 14 V, its maximal output power reaches 220W, it may power most 11-18 V chargers
Specifications:
Input voltage: AC100-240V, AC 50-60Hz
Output: 14V/16A
MAX: 220W
Case: AL-alloy
Dimension: 180*90*50 mm
Weight: 600g
Cool fan: Yes
1. Built in short circuit protection, over-load & over-voltage protection
2. channel outputs simultaneously.
Tech note:
Operating Temperature: 0~50 degree
Storage Temperature: -20~+95%
Operating Relative Humidity: 20%-90%RH
Withstanding Voltage: IP/OP 5mA 1.5KVAC
Insulation Resistance: IP/OP 25A <100m ohms
Package Includes:
- IMAXRC B20 PRO Charger x 1
- Power Cord x 1
- Instruction manual x 1
Great for powering the 4 Bank charger!
