IMAC New Jtec Radiowave Giles 202 builders kit offical release
Discussion in 'Giant / Scale Scratch and Kit Build Threads' started by jtec/radiowave, Jan 17, 2017.
  1. We thought we would share some photos of the new Radiowave 3.1m Giles 202 that we test flew last week. As many of you know the Giles is the predecessor to the MX2 with the major difference being the straight trailing edge design that the Giles has. Since the two airplanes are so closely related and the fact that I love the G-202 it was only a matter of time before we tackled it.
    We are thrilled with how the G-202 flies with no major difference is flight performance and mixing when compared to the MX2. Both planes currently have about 1% rudder to aileron mix.
    Specifications:
    Wing Span: 123 inches (3.1m)
    Wing Area: 2710 sq inches
    Fuselage Length: 113 Inches
    Engine: 150cc - 220cc
    3.1m Giles 202 Builders Kit Features:
    • Interlocking Fuselage Design for self aligning & extremely quick building
    • Includes balsa & hardwood materials needed for construction
    • Premium Fiberglass Cowl & wheel pants
    • Plug In Foam Wings
    • Plug In Foam Stabilizers
    • Foam Vertical Fin & Rudder
    • Designed For Canister Style or Tuned Pipe Exhaust Systems
    • Designed to Accomodate 3 Servos Per Wing
    • Designed to Accomodate 2 Servos Per Elevator Half
    • Built-in Rudder Tray For Pull-Pull Setup
    • Optional Bays for Rudder Servos In The Tail
    • Motor Box with firewall locations for DA-150/170 or DA-200
    • Carbon Fiber Wing Tube & Tail Tube
    The kit it available now with the 2.8m version for the DA100/120 to follow shortly
    For more info on the Giles or the MX2 you can visit our website at www.jtecrc.com
    http://www.GiantScaleNews.com/forums/images/beta/attach/icon-img.png
    Images
    View all Images in thread
    Jetpainter and pawnshopmike like this.
  2. I am considering doing a build thread right from the start showing some of the basic files to laser cutting parts and foam cutting if there is an interest.
    Al
  3. WMcNabb
    WMcNabb 100cc
    836
    1,206
    93
    TN, USA
    Congratulations on the new release! And yes, definitely interested in a build thread!!
    Jetpainter, Wacobipe and Alky6 like this.
  4. BalsaDust
    BalsaDust Moderator
    Yes do a thread. I used to think the Giles was ugly but it has grown on me so much that I'm designing a 20cc profile version of it. Would love to see it in a 30% 55cc format as well.
    Alky6 likes this.
  5. Yes absolutely do a build thread! This is a great looking bird, I'd love to see one go together!
    Alky6 likes this.
  6. Krzy4RC
    Krzy4RC GSN Contributor
    It is beautiful, would love to see the ground up build...
  7. Build thread! Build thread! Build thread!
  8. We started cutting one out last night. We will try and get some pictures posted later. This one will probably be a personal build for Kevin. The material in this build will be a little different as we will be working on the CS version ( Competition Series ) One of the differences will be this will have solid Balsa sides rather than the open bay lightened lite ply sides as the standard version has plus this version will have more carbon. Flight profiles will be the same as everything else will remain the same. Construction will be almost identical as the standard version.
    Al
    Bipeguy03, pawnshopmike and Alky6 like this.
  9. Looking forward to the build thread :) Thanks for the feedback on this and the MX2. Really like these designs.
  10. So late today we started putting things together to start a build. I wanted to just get the longerons done tonight but couldn't find my small miter box to cut them and I hate doing it by hand( wild ass cut). Kevin goes to me " how long do you want the scarf joint" Walks over to the computer, pulls up the auto cad program and in about 5 minutes walks away from the laser with a nifty little tool to cut the angles for the scarf joints.
    Guess what guys, That little tool is now part of the kit!! Keeping it simple!! way to go Kevin!!
    Alky6, pawnshopmike and WMcNabb like this.
