Nib castle edge 120 hv esc 50v $175 conus
RacinjasonR4
Ideal for 550, 600 or 700 class heli’s and giant scale fixed wing aircraft Programmable using Castle Link USB Adapter, CSEM6301 User programmable white auxiliary wire can be used for governor gain input adjustments, serve as an audible beacon after a crash, act as an RPM output for 3 axis gyros that support RPM sensors, and used as an ESC or receiver arming lock One year limited warranty through Castle Creations beginning at date of purchase
INCLUDES:
Phoenix Edge HV 120 Amp 50V ESC with Instruction Sheet
REQUIRES:
Battery and motor connectors of modeler's choice
SPECS:
Input Voltage: 3S-12S LiPo
Max Continuous Amps at Full Throttle: 120
Dimensions: 2.0 x 3.3 x 0.9" (50.8 x 83.6 x 23.2mm
